Alpine-cda7990, Alpine Pxa-h900, McIntosh MCC204,MCC302, Focal 165w3 Utopia, JL Audio
dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 6669 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
למכירה:
1. רדיאו דיסק Alpine-cda7990 מסידרה F1 Status
Sampling Rate ..........................................................................................44.1kHz
Signal-to-Noise (S/N)...............................................................................120.0 dB
Channel Separation (1kHz)........................................................................110.0 dB
Dynamic Range (1kHz) .............................................................................100.0 dB
Total Harmonic Distortion (THD).....................................................................0.002%
Frequency Response .............................................................................5-20k ±1 dB
Number of DACs ................................................................................................3
DAC Type ......................................96kHz/24Bit Sign Magnitude (Burr-Brown K-Grade)
Oversampling ...................................................................................8X/352.8kHz
Wow & Flutter (%WRMS) ................................................................................B.M.L
2. מעבד Alpine Pxa-h900 מסידרה F1 Status
EQ number of bands: Front: 31
Rear: 31
Center: 31
Subwoofer: 10
Graphic equalizer boost cut
range: ±9 dB
Time correction control
range: 0 to 20 ms (0.1 ms steps)
Frequency response: 20 Hz to 20 kHz
S/N ratio: 110 dB
Channel separation: 80 dB
Input sensitivity: 850 mA (2V for analog 1 only)
Subwoofer crossover: 20 to 200 Hz (1/6 oct. steps)
Subwoofer level control: 0 dB to +15 dB
Rated output: 4V (with 10 k ohms load)
Input impedance: 10 k ohms or greater
Output impedance: 1 k ohm or less
3.מגברים מקצועים McIntosh MCC204,MCC302
http://www.mcintoshlabs.com/mcprod/..%5Cdata%5Cmanuals%5CMCC204om.pdf
http://www.mcintoshlabs.com/mcprod/..%5Cdata%5Cmanuals%5CMCC302om.pdf
4. סאב JL Audio 12W7
http://mobile.jlaudio.com/products_subs.php?series_id=9
5. קומפוננט Focal 165w3 Utopia
http://www.unbeatablecaraudio.com/focal/utopia_speakers.htm
6. 3 קבלים Stinger כל אחד 1F.
http://www.ryda.com.au/ProductDetails.asp?ProductCode=SC201B
לפרטים: 050-6922762
  • שבועיים מאוחר יותר ...
  • חודשיים מאוחר יותר...
  • חודש מאוחר יותר...
למכירה נשארו:
2. מגברים McIntosh MCC204,MCC302
3. סאב JL Audio 12W7
4. קומפוננט Focal 165w3 Utopia
5. 2 קבלים Stinger (ללא מד מתח) כל אחד 1F.
