dir="rtl" style="text-align:right;"> שימו לב! השרשור הזה בן 8140 ימים, שזה ממש ממש הרבה ולכן הוא ננעל.
ABS
Anti-lock Breaking System
Allows the vehicle to be steered under heavy braking
A/C
Air Conditioning
Heats, cools, dries and cleans the air inside the vehicle
ACF
Activated Charcoal Filter
Stores fuel vapour from the tank for use in certain throttle conditions
ADR
Automatic Distance Regulation
Works with traction control and Doppler radar to stop the vehicle getting too close to objects in front
APC
Automatic Proximity Control
ASR
Anti-Slip Regulation
Reduces the engine torque when the driving wheels lose traction
CCS
Cruise Control System
Allows the vehicle to be set at a cruising speed and keeps this speed constant
CDU
Central Display Unit
This is mounted on the dash and displays the vehicle’s running information
DATD
Diesel Anti-Theft Device
An immobiliser built into diesel engine vehicles
DRC
Dynamic Ride Control
A function of the vehicle’s suspension that controls body roll
DSP
Digital Sound Package
Features a Graphic Equaliser and a sound modulator
EBA
Electronic Brake Assist
Assists the driver by adding extra brake force in an emergency situation
EBD
Electronic Brake-force Distribution
Replaces the mechanical brake compensator
EDL
Electronic Differential Lock
This locks the degree of difference between the driving wheels to provide greater traction
EMS
Electrical/Mechanical Steering
Electro-hydraulic power steering using an electric pump instead of an engine-driven pump
EPC
Electronic Programme Check
Control unit link check system
ESP
Electronic Stability Programme
Uses both the TCS and ABC to keep the car stable on corners
EW
Electric Windows
Electrically operated windows
GPS
Global Positioning System
A navigation system using 29 satellites to triangulated a car’s position to within a few feet
HRC
Headlight Range Control
Height adjustment for the vehicle’s headlamps to compensate for different loadings
HRW
Heated Rear Window
Stops the rear window from steaming up
HWS
Headlight Washer System
Screenwash is squirted under pressure at the headlamps to remove road dirt
KESSY
Keyless Entry Start SYstem
A microchip embedded in a card that allows the doors to open and the engine to start
MBA
Mechanical Brake Assistance
When force is applied to the pedal, a servo increases the braking effort
MSR
Motor Slip Regulation
A traction control system that increases engine speed to maintain road holding
PAS
Power Assisted Steering
Hydraulic assistance on the steering rack to make the car ‘lighter’ to turn
RCL
Remote Central Locking
Enables the vehicle doors to be locked and unlocked without the turn of a key
RWW
Rear Wash/Wipe
Clears the rear windscreen
SL
Synthetic Leather
Leatherette, which looks and feels like leather but won’t dry out
TCS
Traction Control System
Stops the driving wheels losing road hold
TPC
Tyre Pressure Check
Constantly checks the tyre pressure and displays the results on the CDU
Every man has his own destiny: the only imperative is to follow it, to accept it, no matter where it leads him
Henry Miller
יש עוד מספר ראשי תיבות, בנוסף ל"כל" הנ"ל:
http://hem.passagen.se/realcars/gloss/abbrevs.htm
הלינק הזה פורסם פעם בפורום.
:multi: רז .
נמכרה.
טיול נהיגה
בפורשה קאררה 4 GTS.
המרצדס שלי
נמכרה.
אף פעם לא ראיתי את הלינק הזה תודה .
בכל מקרה התכוונתי לראשי התיבות בתוך האוטו ולא הקשורים לא כמו GTO וכאלה . אבל אחלה של לינק סיפקת לי ... תמיד רציתי לדעת את הפירושים האלה :wink:
Henry Miller
